Hello, how are I such, I have problems with an ETA Nissan Murano 2006 truck, the system marks everything 100% but fails to start the truck; I already changed crankshaft and cam tree trees, the immobilizer and GPS system was already checked but it still does not start.
Already check the key of the key even another chip is scheduled the witness of the immobilizer is erased to have had the swich the gasoline bonba works, there is no spark in the coils, if Coriente arrives at the coils and the sensors. And the signal signal if they reach a loading path that is on the side of the co -pilot on the side of outside where the engine is and hears that reaches the relays. Upon arrival at the relay signal, the pump is activated again but it does not start. I hope you can help me
