Problem with Cavalier 1993
16 years 4 months before #6547 by manual-mecanica
Problem with Cavalier 1993 published by Manual-Mecanica
Hello little help I have just acquired a 1996 cavalier is in good condition I plan to restore just ask if Algien knows what a kind of memory that comes in the molding that serves as a cover to the fuse box below the bowling is served as it brings it disconnected and I do not know if that makes that to accelerate a little it feels like it is drowning but when accelerating more it is composed thanks
16 years 4 months before #6573 by manual-mecanica
Manual-Mecanica Response on the Re: Problem with Cavalier 1993
I really don't know what memory you are talking about but in short, if it goes in the inner fucilera, would not affect the problem, the problem is another, is it a oil or bencinero?
16 years 4 months before #6653 by manual-mecanica
You should look at the carburetor if it has manual or electronic low, the electronics connects to the high coil, if it does not work on a low drowns and in high resurrect, if it is manual it is evil regulated, it is a simple chicler, but you will have to regulate the carburetor in low and very hot the engine to stop failing, you are missing air in the regulation of the low. The Royal Mescla is 14 from Nafta Air
