Failure in Thunder SC 91
16 years 4 months before #6594 by manual-mecanica
Failure in Thunder SC 91 Published by Manual-Mecanica
Hello friends:
I have a problem with my Thunder SC 91 since when it turns it on cold it ignites without problems but begins to put explosions for the escape; The cables and spark plugs are new, I don't know if it is because it does not have the exhaust tube or another failure.
It is also that when you warm up and put Drive, the revolutions are too much and the failure of wanting to go out, I marks the Check Gages failure.
Could you help me
16 years 4 months before #6600 by manual-mecanica
Manual-Mecanica Response on the Re: Failure in Thunder SC 91
If Chek's failure marks you and you don't give us a little more information, it is difficult Liberating very quickly and that is why the failure to right, but it is complicated to say, if you have the escape outside, see how it goes, if the cables and spark plugs are well to check the compretion that the system is carbonized and the valves do not apply correctly, but first of all put the escape,
