1997 Neon Chrysler
16 years 4 months before #6605 by manual-mecanica
Neon Chrysler of 1997 published by Manual-Mecanica
First of all, thank you all for your contributions. My query is as follows: I have a neon, and this motor racing sometimes stops working for the engine without apparent reason and feels a smell of gasoline and after a few seconds again light the engine and sometimes continues without giving problems. If I have noticed what it does when the acceleration is low. Thanks for the attention given to it your friend Edwin Mudarra. Greetings from Panama.
16 years 4 months before #6627 by manual-mecanica
Manual-Mecanica Response on the Re: Neon Chrysler 1997
Apparently your car fails the slowdown, that's why I stop when you don't have the accelerator footprint, isn't it? Take it to a workshop to check it. I drop where the neon regulator has.B)
luck is pag.
www.forocoches.com/for/showthread.php?t=734128
16 years 4 months before #6632 by manual-mecanica
Check the IAC what is cut in your car is the current not the gasoline of Ahy the strong smell, check the IAC clean it and do not improve it, the iac ban in the body of admission serca of the TPS
16 years 4 months before #6635 by manual-mecanica
Thanks friends for your contributions. Proceed to clean or change the indicated piece. God bless you. Greetings from Panama.
