problem with the piston one nissan pathfinder v6
16 years 3 months before #7325 by manual-mecanica
Hello, I have problems with my Nissan Pathfinder 2001 V6 3500cc. Check Engine tells me that the piston fails but it is not all the time, the fault is lost but the check is ignited. I already changed the spark plugs if the spark plugs that put are good bosch super 4 I already did injectors cleaning. Please you know how to fix my problem I wait for the RSPUESTO soon thanks.
Atte.
ROLY
16 years 3 months before #7337 by manual-mecanica
I recommend that before doing any thing you change the spark plug wires, the one you can do to prompt is change the cable of the piston that does not work for someone who works and the assumption you put it where you take the other if it fails in the other cylinder changes the cables and already, if you fail both of you let me know and solve it.
16 years 2 months before #7436 by manual-mecanica
Hello, this problem occurs mainly due to defective ignition (cables, spark plugs, coil) but on occasion it can also be an obstructed injector, which is not always solved with cleaning with buoy or presurized liquid, if you already tried spark plug cables and I recommend you try the operation of the injectors outside the vehicle (injectors laboratory) with this you will realize if you are injecting the same amount of fuel. Check it and let me know to sleep quiet ok?
15 years 11 months before #8757 by manual-mecanica
Hello, the problem is still checking the injectors are fine the problem that I have is not always just when I turn on but Rarce Avez fails the check tells me that it is the piston one that goes out but I throw a good accelerated and stop failing and the gasoline filter changes and I do not change the gasoline filter and I do not change in anything I can not be and also consumes me more gasoline than normal I expect a prompt response. Thank you
15 years 11 months before #8759 by manual-mecanica
Friend did you check the cables or not?
