problem with the piston one nissan pathfinder v6
15 years 11 months before #8771 by manual-mecanica
Hello I saw the cables the problem that carries a coil the current that comes to the coil is good
15 years 11 months before #8774 by manual-mecanica
what? I don't understand what you mean,
15 years 11 months before #8828 by manual-mecanica
MR503
;) These spark plugs are very good but because of other experiences that I had, not all engines work the same. I suggest that I put the original (new) spark plugs.
But what I wanted to ask is that if before changing the spark plugs he mentions (Bosh Super 4) he already had the fault.: HUH:
15 years 10 months before #8844 by manual-mecanica
Roly Hello changes a cable from one spark plug on the other and check the cable that goes to the injector may have a false contact or an interrupted cable somewhere
15 years 10 months before #8845 by manual-mecanica
If I already had the root failure of that fault that changed the spark plugs and I did in injection of injectors but the fault followed that I think it is the gasoline that very bad here in Bolivia. Well anyway thanks for the help. Chau
