Ford Fiesta 97
16 years 2 months before #7415 by manual-mecanica
Ford Fiesta 97 Published by Manual-Mecanica
The problem is when the vehicle turns on at 1500RPM, floor or under the clutch drops to 800rpm, I release the clutch pedal and climb to 1000 rpm, at this time they climbed 3000 rpm, and recave, I hope they give me an idea about this, thanks beforehand thank you
16 years 2 months before #7430 by manual-mecanica
Manual-Mecanica Answer on the Re: Ford Fiesta 97
What repacation have done to that vehicle? Is it mechanical or automatic?, the light of check turns on? refrigeration also bothers like this
16 years 2 months before #7433 by manual-mecanica
Only the system was cleaned because it was very dirty, with oil of the disgust throughout the fuel admitting system, it was off and the rpm variables, ... with reference to the air the RPM rose to 3000 when the air turned on, thanks for the orientation
16 years 2 months before #7442 by manual-mecanica
Check that there is no air in the IAC, if not the strangle pass and the valve sticks, revias the air in the refrigeration system, it may be that when the air circuit does not fill it, there is some bubble. But if you have to turn off the most caused is the IAC,
16 years 2 months before #7469 by manual-mecanica
The IAC valve possibly also passes if the aseleration smallness is very corroid or damaged the lining that covers the line is of metal because it passes me once.
Now the A/C magnifies any engine failure I know from experience.
If you have a Scaner it would be good to know the codes.
