Auto ran out of gas and now it doesn't start
16 years 2 months before #7499 by manual-mecanica
Another fact, the pump is mechanical. The strange thing is that when he ran out of gas I went to buy it in the tank and a little in the carburetor, he immediately started. I kept it at home and when I wanted to leave again it didn't start at all.
16 years 2 months before #7501 by manual-mecanica
Look if, in the vehicle, the vehicle is correctly, it is not very caused that it is the pump, if it were bad not to start, more fuel does not mean more precion of it, it has nothing to do with the amount, not being that the tank is deformed, most likely it is that as you dried the pond all the dirt that avia in the there arrived at the carburetor and obstructed some of the gum or lock It is normal for this to pass, you can try until it starts or carry it so that they clean it, they are not delayed much and it is relatively baroto if you do not dare yourself, being double gargant you have one of them that works on a lower and another one in high, when pushing it would start from anyway because it always exite a little fuel that passes,
16 years 2 months before #7502 by manual-mecanica
Look that I decided to throw the tank and clean it well, while I am going to take the carburetor to review it. Thanks for your help
16 years 2 months before #7509 by manual-mecanica
At all is the best thing you can do the carburetors I am complicated when you have not had a practice with them, that is why I cannot tell you that you disassemble you to assemble them is very delicate, luck
