Check the connection of the captors ahy vehicles that use two one for each coil, I do not know your case very well your engine but you may give you a track, the connection that reaches the second coil or first nose which is the one that fails you, follow the path of cables and fix that they do not cut anywhere, your coil is Dis or you have two coils.
