Aid!!! I need to connect the ignition module
16 years 2 months before #7591 by manual-mecanica
Aid!!! I need to connect the ignition module published by Manual-Mecanica
I would thank you to tell me what the polarity of this ignition module is please:
www.ignion-tw.com/detail/203584 ...
It only brings 2 "teeth" is the one on the left (+) and the one on the right (-)? What would happen if I connect it badly?
I do not want to burn it so I consult the experts ... I clarify that I have no multimeter or anything like that to make measurements.
16 years 2 months before #7592 by manual-mecanica
Hello, if you need to start this module. If the decriction you give with respect to the polarida, connect the positive (+) terminal of the module to the positive terminal of the coil and the negative (-) of the module to the negative of the coil. Verify that electric current arrives to the positive terminal of the coil. LUCK
16 years 2 months before #7594 by manual-mecanica
Hello, first that is not a ignition module, it is an inductive captor and if you put it to the setling it does not work but does not burn
16 years 2 months before #7597 by manual-mecanica
It is the ignition module that is within the distributor of a Nissan. What happens is that it does not indicate which of its connectors is +
16 years 2 months before #7598 by manual-mecanica
I do not know which of the 2 connectors of this module is the terminal +, it does not indicate. What happens if I connect it by exchanging polarity, it burns? Is it short in the fuse box?
