If it is from 95 minimum it would have to be monopunto not carbonated, if you had injection problem your chek would turn on, of course if it is good, as I always say and recommend, it is best to perform a Scaner when the problem is Chek, now because of the symptoms that you give me that sucks me, to my parser the first thing is to make a tune, change of air filter, bench filter, spark plugs, spark plugs and cables The state of Catalan that is not covered, and if you can measure the compression, but I believe that with the tuning it will walk well.
