Does not start the Megane 1 motorcycle
15 years 10 months before #8922 by manual-mecanica
Does not start the Megane 1 motorcycler posted by Manual-Mecanica
This is a megane 5 doors 2005 1.6 last and I have it from 0 km. Please I need to help me detect what the fault can be. If the solution is simple, I implement it and voila. If not, if the thing is heavier, I take it to Renault to repair and I hope they cut my head. Heh
15 years 10 months before #8953 by manual-mecanica
Manual-Mecanica response on the Re: does not start the Megane 1 motorcycler 1
Start by checking the fuses if you are all good you are looking for the temperature sensor that the fan starts, it should be on the radiator if you get it you make a bridge and see if it starts if you do not start you can try the direct fan with two cables, if you do not start then it can be the fan if it starts it is possible that it is the wiring, it is a little help of what it can be, greetings Alf.-
15 years 10 months before #8954 by manual-mecanica
With the engine and switch off, test first with the hand if it turns free the fan, it is possible that the fan elective motor will be looked, then you can test fuses, electrical wiring and temperature bulb. :)
15 years 10 months before #8996 by manual-mecanica
Thank you short circuit, the fuses are fine and the Mootor function with the AA. I will look where the temperature bulb is. Hug
15 years 10 months before #8997 by manual-mecanica
Manual-Mecanica Response on the Re: Re: Do not start the Megane 1 Motor
Thanks Ober60, the fuses are fine and the Mootor function with the AA. I will look where the temperature bulb is. Hug
