Vibration in the Fiat Siena Diesel flyer
15 years 10 months before #8927 by manual-mecanica
Vibration in the Fiat Siena Diesel flyer published by Manual-Mecanica
I have a problem in my Fiat Siena Diesel, which after arranging it, being cold or hot, a very strong vibration is produced in the steering wheel when the engine is in idle, very rarely does not do so in the same conditions.
15 years 10 months before #8937 by manual-mecanica
Hello companion, check that the idle is not too low, it must be 950 to 1000 rpm also check that the air filter is clean and greetings.
15 years 10 months before #8939 by manual-mecanica
The idle is correct and the air filter has 500 km, since I changed it recently. Thank you to respond.
15 years 10 months before #8947 by manual-mecanica
Then control the tightening of the direction zipper and the column greetings.
15 years 10 months before #8951 by manual-mecanica
It can be a motor support such as the exhaust that is touching you somewhere in the body can also be some air pipe that is playing in the body, this is if you have already checked what is engine both turns of the minimum engine and if all cylinders work correctly.-
