accelerated vehicle
14 years 2 months before #20546 by manual-mecanica
accelerated vehicle published by Manual-Mecanica
I have a 97 outbback that is accelerated. Every time I get into the vehicle, it accelerates, Ñllega up to 2500 rpm, why will it be? please orientation, because I am from a small town and here the vehicles and the mechanics do not give the failure. Bencina sucks as bad from the head. Thank you for your help.
14 years 2 months before #20547 by manual-mecanica
Manual-Mecanica Response on the re: accelerated vehicle
Hello compadre I have a problem, I have a 1998 Ford Ranger Cab 1/2 and the same thing happens to me when I am stopping and clutch to leave I am accelerated as at 1500rpm I think it could be the oxygen sensor because sometimes I turn on the check Ingine, I hope someone can answer this consultation since we could be several beneficiaries
14 years 2 months before - 14 years 2 months before #20550 by manual-mecanica
Friends: Apparently in both vehicles the fault is the same, it is a failure in the idle control actuator. It is generally broken and when the vehicle is running, it opens to compensate for the deceleration, but it does not close again when the engine is left in idle, which causes the engine to be accelerated (and frequently tends to accelerate more and more).
The most appropriate would be trying to disconnect it after starting the engine to leave it fixed to those revolutions, as the engine should start with normal rpm and then accelerate due to the failure. The vehicle must be tested to verify if the revolutions of the same are normalized with the disconnected actuator.
All this is strictly as proof.
If so, you have to replace the idle control valve (IAC) to solve the problem.
If after that test the problem persists, the output voltage of the Lambda probe (oxygen sensor) that should be ranging between 0 and 900 MV must be measured. If the sensor readings will be fixed in a value means that the problem has another origin. If the oxygen sensor readings tend to 900 MV, the temperature sensor (CTS) of the refrigerant, the admission air temperature (IAT) and the air flow flow sensor (MAF or fluctioner) would have to verify.
If the oxygen sensor voltage from the moment of the start is fixed in approx 500 mv, then the sensor is defective and must be replaced.
It is important to know that the luminous witness "Check Engine" does not exclusively indicate an oxygen sensor failure (that has become a quasi-mit), but it is actually an indicator of failure in the engine control system, bone of all components of the electronic system, be it a sensor, an actuator or several of them. If the "check Engine" is turned on with the engine running, it means that some component of the engine control system is failing so the possibilities are very varied.
I hope my response will help you.
Greetings from Chile.
Latest edition: 14 years 2 months before by .
14 years 2 months before #20551 by manual-mecanica
Thanks estimated for the answer, from Chilean Patagonia a greeting for you
14 years 2 months before #20553 by manual-mecanica
Temuco - Chile data
