Antonio Carraro Tractor Problem ...
15 years 3 months before #12188 by manual-mecanica
Antonio Carraro Tractor Problem ... Published by Manual-Mecanica
I have a tractor Antonio Carraro Tigre 3400, and my problem is that it is very difficult to start to the point of putting the tweezers, putting them out after the time starts.
I have tried everything, change of battery, heater, oil, filters and yet it does not start the first, a fact is that a lot of white smoke when trying to tear it away, having if someone can help me, thanks before hand
15 years 3 months before #12203 by manual-mecanica
Manual-Mecanica Answer on the Re: Tractor Problem Antonio Carraro ...
I can help you but I would like to know what type of engine it has it is possible according to the diagnosis that you give of the white smoke that is injection problem if it is a diesel engine, or perhaps compression problem since the valves are not sitting good and if you want to turn it very urgently the last alternative is that you put it to breathe gasoline while you give it start.
15 years 2 months before #12719 by manual-mecanica
If it is Diesel Papaz to run the point of the bomb, it regulates well? The other you have a fissure or something in the part of the fuel lines check everything and if you can directly change it (filters, handles, etc.) Greetings
15 years 2 months before #12726 by manual-mecanica
Check the feed pump. It is taken to the motor block, there comes the spadin hose of the diesel storage. This pump in some models can be disassembled. It has a small filter of usually capping dirt.
I have a Axcavator with Perkins 1004 engine and carries this pump. The hose is disassembled and with a key of 27 unscrew the entrance.
15 years 2 months before #12732 by manual-mecanica
