Putting Suzuki Baleno
13 years 11 months before #23403 by manual-mecanica
Tuning Suzuki Baleno published by Manual-Mecanica
I hope you can help me, I can not put a balenic suzuki 1.3, according to the manua the marks are clear but not part, I put it ready without marks just leaving the cylinder one above and the lebas in balancing and partium but it stops immediately. I hope someone helps me. Thanks in advance
13 years 11 months before #23420 by manual-mecanica
Manual-Mecanica Answer on the Rezuki Baleno tuning
In fact, the marks are clear and if you are looking for the manual you will realize how clear they are, but have an eye on the cams's position if you took out the pulley enters two positions, now if you leave well and keep it accelerated should not stop, because of the set -up, you may have something disconnected hoses or cables, what repair did you make your engine.
13 years 11 months before #23430 by manual-mecanica
The brands are clear and according to manual I have everything ok but, with those brands I don't part.
13 years 11 months before #23446 by manual-mecanica
I repair it but the pulley and distribution is well ready, inject benzina and has a spark but when you take out the spark plugs after turning the engine they come out wet that indicates that the spark is not at the right time. Will it be a problem of any sensor? thank you
13 years 11 months before #23465 by manual-mecanica
Difficult if you crashed everything, but it can be some Czech emptiness hose that you connected everything, sometimes some minor detail is overlooked and that is the whole problem.
