206 GTI does not start
13 years 8 months before #26187 by manual-mecanica
206 GTI does not start published by Manual-Mecanica
I have a 206 GTI. And on Thursday I started changing a fuse of the lighter but since Nolo found or I have the car manual to remove all the fuses. what was my surprise that devi remove the electronic antiarranque and I think all the keys have been decoded. I do not know if you could there because I will take it to the Peugeot to see that I have been on Tuesday thanks in advance.
13 years 8 months before #26195 by manual-mecanica
Manual-Mecanica Response on the Re: 206 GTI does not start
Hello, the immo system fuse is the same as that of the radio.
13 years 8 months before #26213 by manual-mecanica
Thanks for answering but I think the immobilizer charged. That the key code is lost and that is why it does not start. But I asked by if you could recover the code without having to take it to the workshop. Anyway, Luis. Thank you and health
13 years 8 months before #26221 by manual-mecanica
The memory that contains the antiarranque code is a non -volatile memory, that is, its information is not lost yet without food, Rev if any fuse is needed or if there is any burned.
13 years 8 months before #26224 by manual-mecanica
It is important that all operations that are done in terms of fuses and electrical parts can be done with the vehicle off and if possible with the disconnected battery (if it has an electronic butterfly, leave the vehicle still for about 10 min, before deconcing) after verifying that the fuses are placed by giving the battery, then open and close the switch about 2 times, 30 sec C/u to learn the key. I hope it is helpful.
