Time chain Nissan Sentra Gxe Motor Ga16
13 years 7 months before #27560 by manual-mecanica
Time chain Nissan Sentra Gxe Motor GA16 Published by Manual-Mecanica
Hello, Nesecito helps, it turns out that this vehicle sounds to the chain when it turns on it, it is average to change it an armed vessel does not give me a 50lbs frame by cylinder, but there are no folded valbules already reviewed any idea of ​​how to overcome the chain I use a scheme that I present but it does not work in that I am equating? I leave a photo of the type of chain that uses this Nissan.
13 years 7 months before #27569 by manual-mecanica
Manual-Mecanica Response on the Re: Time Chain Nissan Sentra Gxe Motor GA16
Place your chain as the diagram says and check that it is correctly synchronized by guiding you with the overlap of valves of the 4 cylinder, if it is fine, 2 turns to the crankshaft and verify again that it is well synchronized.
Note: Your engine is not the GA16, according to the photos it is the ga16de that brings the VTC system, perhaps this is the one that is giving you problems
13 years 7 months before #27574 by manual-mecanica
Putting that chain is the potato only make sure that the first chain's draft is in the three brands and then you put the second and already, the double pinion brand is not the same for the short and long chain. If there are no bent valves then the crankshaft is not properly draft.
13 years 7 months before #27600 by manual-mecanica
Hello friend ... If the distribution is already armed and you are giving you problems, do not remove the lower distribution lid just remove the head of the head, put the piston one on PMS and place the small chain with the valves in overlap and forget the marks ... pear this tine q remove the 2 tensioners ... ready
13 years 7 months before #28342 by manual-mecanica
: Woohoo: Hello, I finally solved the problem, I do not touch another to disassemble coca accent valves and change rings in pistons. It turns out that this vehicle only brings two rings per piston and with a very easy bad maintenance and compression is lost and what happened in this case. Thanks to those who contributed it is an experience of failure that not very easy to forget. Thanks and greetings.
