Good my problem is that the changes or marches enter, but the wheels do not move or the car goes out to your see the changes pass without pressing the clutch
I saw in
a post that the differential \ "escape \" the whole movement just as if you had a wheel in the air. 2º The primary of the gearbox or the striatum on the disc has been broken or something strange passes inside the clutch.
To know which of the two things is, lift the car so that the motor wheels are in the air. Enter first or reverse with the standing engine and wheels in the air and turn one of the two wheels with your hand.
If the wheel in front of which you move with your hand, turn in the opposite direction to the one you are giving it means that the differential and transmissions are correctly and that you have to think about the primary or the clutch.
If on the contrary, the wheel in front does nothing while you are turning the other, it means that you have a broken stick, or out of place
Thank you very much
