Start problem Mitsubishi Galant 1.8 1991
16 years 9 months before - 16 years 9 months before #4412 by manual-mecanica
Start problem Mitsubishi Galant 1.8 1991 Published by Manual-Mecanica
Hello everyone, I just found this site that seems great to me! ... I tell you my problem if you can help me ... as I mention in the title, I have a mitsubishi galant super saloon displacement 1.8 lt. Year 1991. The problem it has is that it is not coming to the spark plugs. In the first place I thought that the battery could be, I changed it now, when I followed the problem I thought it could be some fuse, I reviewed them all ... None burned ... I tried if I was coming to the coil and even there it arrives, I changed it for a new one and the problem continues ... by there someone told me that it could be the condenser ... I changed it for a new one but the problem persists ... I no longer know what more can be !! I greatly thank you for your help! If you need more information, I detail those who need
thanks again, and greetings !!
Last edition: 16 years 9 months before by .
16 years 9 months before #4413 by manual-mecanica
Manual-Mecanica Response on the Re: Start Problem Mitsubishi Galant 1.8 1991
Your car is from platinos if so, it could be the roor of the ofco but can be the platinum that does not make contact and does not succeed, the coil,
16 years 9 months before #4425 by manual-mecanica
A 91 car with platinos ???? Nor case ....
Check the hall sensor that goes in a distributor, they usually fail and not giving the reference of the 1st cylinder, there is no spark. You should also check the ignition pill, positive and dough feed, and the spark jump signal.
16 years 9 months before #4430 by manual-mecanica
Hello, they are correct, the car is from platinos (it was with electronic ignition but for a problem of the ignition module and its cost decided to return to the conventional ignition) .... I will review everything you tell me and post the results,
greetings and thank you !!
16 years 9 months before #4446 by manual-mecanica
Friend Rekoveco in this world never ends up learning.- Take out the cable that comes from the coil and see if it comes out if so connect again and see if it goes out to the spark plugs if it is not like this possibly broken or rotor of the distributor.- Check and let me know.-
