Kia Picanto rear stop lights fails
16 years 6 months before #5694 by manual-mecanica
How friends, I have the next problem, a month ago I have detected that the rear stop lights of my car do not light, check the fuse is fine, the light bulbs, they told me that it could be the brake pedal switch, how can I check if it is good or not? I await your comments ..
16 years 6 months before #5698 by manual-mecanica
Manual-Mecanica Response On the Re: Kia Picanto rear stop lights fails
Hi Josnene, you effectively have problems with the brake pedal switch, because that is the one who commands the lights, you do not talk to me the brand or model but you can usually remove it in a simple way only bring two or three screws, birds can be nuts and go with a fixed thread, well this is a button but it would be useful to put the test where the connections are Pito how you want to press the button and stop marking, if you don't have a tester you can do it with an test lamp you connect the cables and see if the Lus turns on, that's all.
16 years 6 months before #5705 by manual-mecanica
And you can also do a very simple test, bridge the cables with the contact on and look behind.
It is possible that the button goes simply or with a metal clip that holds it. You will see that when putting your head on the car pedalier. Help yourself with a flashlight or do it in the street in the sun because under the steering wheel there is almost nothing.
All the best.
16 years 6 months before #5759 by manual-mecanica
Ok thank you very much for the information, I will take the test and would take you later, now, if any of you, knows someone who has the Kia Picanto workshop manual, I would appreciate them greatly, awaiting their comments, greetings, greetings, greetings,
16 years 6 months before #5824 by manual-mecanica
ATTENTION If the switch has two or four cables
