I hope someone can help me
16 years 5 months before #6542 by manual-mecanica
Hopefully someone can help me published by Manual-Mecanica
I have a sorento kia of 2002, the odometer and the speedometer run normal when starting the march, but then with the movement, sometimes they stop; They told me that it was the speed sensor that was wrong, I changed it for another original and it turns out that it remains the same. Someone knows something about this failure.
16 years 5 months before #6543 by manual-mecanica
Manual-Mecanica Answer on the Re: Hopefully someone can help me
Try to change the instrument picture
16 years 5 months before #6571 by manual-mecanica
I do not think that the instrument picture has a lot to do, but it is always good
15 years 7 months before #10646 by manual-mecanica
Maybe here you can give you the answer
www.sorentoweb.com/index.php?module=pnPHPB2
15 years 6 months before #10732 by manual-mecanica
It seems a connection that is failing, check if the alternator carries a cable in the W connection, verifies that it is correctly connected.
Greetings
luck
