Opel Astra G address
16 years 4 months before #6981 by manual-mecanica
Opel Astra G address published by Manual-Mecanica
Hello, I have a problem with the direction of one of the arms and I am fixed that the El Hydraulic boat is everything stained with hydraulic on the outside I would like to know what kind of hydraulic carries and level or if you have to do a bleeding or something like that
16 years 4 months before #6998 by manual-mecanica
Manual-Mecanica Response on the Rera G
The bleeding does it alone and I am not sure but normally they carry the ATF, you can ask in the Opel or check in the owner's manual that there are all the types of oil that the car uses, advice washing the full of oil before and after repairing, if it is by the arm it is sure that it is the internal retain of the direction box.-
16 years 4 months before #7023 by manual-mecanica
Well, just in case I have the entire address system located in a scrap.
16 years 4 months before #7024 by manual-mecanica
If you are going to change it so that you are going to send it to Seville and the washing is the area where the boat is seen so that you can evaluate well where it is losing
16 years 4 months before #7025 by manual-mecanica
It is worth reading your message 18 times I think that I clear will be to check where it loses exactly and then see if it loses and the level?
