Subaru 600 temperature
15 years 11 months before #8620 by manual-mecanica
Subaru 600 temperature posted by Manual-Mecanica
Hello, I need help with a 600 sub -Uru, I did the whole engine, I sent you to clean the radiator. But I can't do that no temperature. I would appreciate a hand
15 years 11 months before #8627 by manual-mecanica
Manual-Mecanica Response on the Re: Subaru 600 Temperature
Hello companion, check the thermostat well and control the hug.
15 years 11 months before #8637 by manual-mecanica
Check on the part, first if you do not boot the water, second that does not lower the level, then thermostat, take it out if necessary, check that the electrventillator works correctly, if you have thermos check that traces when it corresponds, if it is electro checks the temperature bulb, it would serve us if you told us that year is your sub -row and if it has thermos or electrventillator so we can help you better.
15 years 11 months before - 15 years 11 months before #8641 by manual-mecanica
Hello, it is a 600 Ban Subaru Model 1981, it has a back and radiator engine in front, it is bicilindric has electro to which a manual command connects the vulvo failed and the temperature rises anyway. Thanks for your answer,
Latest edition: 15 years 11 months before by .
15 years 11 months before #8648 by manual-mecanica
Are the electrventilator walking your vehicle the same? If your answer is yes, I tell you since you have the crooked butt, if it does not heat up with the electro direct then the passage of water is evil and this can be the product of the water pump. Check this and let us know.
