How to self -diagnose a Pathfinder VG33E 2000
15 years 10 months before #9030 by manual-mecanica
As self-diagnosis a Pathfinder VG33E 2000 published by Manual-Mecanica
Buy a 2000 path with VG33e engine and the engine fails, as I do to check the eccs without scan:( are rookie,: Woohoo:
15 years 10 months before #9033 by manual-mecanica
Manual-Mecanica Response on the Re: as self-diagnosis a Pathfinder VG33E 2000
Look not everything solves a Scaner is a good assistant but it does not have all the answers it would be easier to tell us the failures that your unit causes you and I do not doubt that one of the many who visit this forum guides you about your problem greetings. : Woohoo:
15 years 10 months before #9038 by manual-mecanica
It is true that you tell us the symptoms also if you do not have the light of Chek taught the scan does not reconcose Nadda, it also does not give codes bridge pins because it has an OBD2 shot
15 years 10 months before #9044 by manual-mecanica
Motor problems does not deliver almost nothing only has the engine 100,000km and smells like gas when it turns on and when I am in the traffic. : Blink:
15 years 10 months before #9056 by manual-mecanica
Have you ever taught you?
