Berlingo 2001 rearview mirror change
15 years 10 months before #9052 by manual-mecanica
Berlingo 2001 rearview mirror change published by Manual-Mecanica
I have to change the right rearview mirror of my Berlingo 2001. There is some guide that explains how to do it, since I do not want to damage the door panel when removing it. Thank you very much, Axel
15 years 10 months before #9062 by manual-mecanica
Manual-Mecanica Response on the Re: Change of Rearvisor Berlingo 2001
I have never changed it but I think that anchor bolts are under a plastic cuvert, which only goes on you take it out and take out the bolts if it is the same as it expresses it, but it is only a matter of looking there are no manuals for that, if you want to take a picture and we tell you.
15 years 10 months before #9086 by manual-mecanica
Thank you, the plastic cover already takes it out, the problem is that the mirror has the engine, and the cable connects inside the door. I don't know how to get the door panel without breaking it, to connect the cable.
15 years 10 months before #9091 by manual-mecanica
To get that you have to remove everything that is bold in a orizontal form, if you do not have glass rise, you will have to remove the handle that lifts the window has a U -shaped insurance that comes out with a palette screwdriver for the separation that remains between the handle and the door, then you throw it towards Arri and withdraws.
15 years 10 months before #9148 by manual-mecanica
Thanks again. I have electric glass rise so it's not a problem. Already unlock all the bolts (white) around the door. The panel now is only holding to the door, behind the internal handle to open the door. Do you have any idea how I do to unlock the handle without breaking anything?
