Air with little flow
15 years 9 months before #9410 by manual-mecanica
Air with little flow published by Manual-Mecanica
Hello everyone and thanks in advance
I have a Fiat Doblo 2004 in which the air comes out without force: Angry :, makes the noise of always
but so that it is noticed you have to put it in the 4 when I always had it on the 2
I think it has to have some filter or something obstructed, can that be that?: HUH: , how do I get to the filter to capitalize?: UNSURE: .
Thanks again
15 years 9 months before #9414 by manual-mecanica
Manual-Mecanica response on the re: air with little flow
Acasegra I have a doubt with your problem, the ruletilla in the two no longer throws you or throws very little?
15 years 9 months before #9415 by manual-mecanica
It does not leave air that you have to put it in the 4
15 years 9 months before #9420 by manual-mecanica
Look if this is how you say it, the rule is checked when they spoil the speeds only the fourth is the direct.
15 years 9 months before #9421 by manual-mecanica
Thank you very much Kikemec, but how could you check the rule?
