Install Count Volutions
17 years 7 months before #1723 by manual-mecanica
Install Taist Volutions Published by Manual-Mecanica
I have a VW 1600 electronic injection engine, I want to set up a tapervolutions but I know you have to connect the AA coil cable but my engine has no coil where I have to connect it?
17 years 7 months before #1724 by manual-mecanica
Manual-Mecanica Response on the Re: Install Taist Voluciones
PHOTO OF THE HELD
[IMG
17 years 7 months before #1731 by manual-mecanica
Hi Vori, welcome to the forum, how do you not have your engine on ??? hahahaha and in the photo what goes out? (It's a joke)
Let's see, I would need to also throw another picture of the distributor, or at least tell me the ignition mark, (Bosch Magnetti Marelli delco Remy ...) It seems to me that the ignition pill is carried under the coil although I do not see it very well. As in the Bosch de Opel.
In this case, the assembly is very simple, first you have to feed the watch with positive contact and dough, (I appear that all that you will have done).
Although in the photo it is not seen, two cables from the pill to the ignition coil have to leave, one is positive of contact and the other is a dough that is where you have to plug the cable that comes from the clock to tell the clock. There is no danger of burning anything.
Greetings and you know that if you have any questions you have nothing more than sending a post or sending me a private ok?
17 years 7 months before #1741 by manual-mecanica
[IMG
Hello megabeat_1, I tell you, it is not the typical coil that is always known
The brand of this is themic is originally from Volkswagen Audi has the two painted symbols, and is made in Mexico.
Theco is very normal as almost all black from the Bosch brand
The positive and dough is already placed to light just connect the signal
The weekend I will try with the polyimetter to see what the mass cable is and I will tell you.
thank you.
17 years 7 months before #1750 by manual-mecanica
Very well, tell us your advances ... and here we also have square ignition coils, such as the one that your volkswagen, the Opel Corsa de Gasolina also carried those coils equal to yours.
All the best!!
