perki
10 years 10 months before #47016 by manual-mecanica
Perki published by Manual-Mecanica
I have a motor that heats up every time and the joint is taken already retains the lid and continues in the same thing I plan to disarma and lead to retain the block the engine is a marine pelki deme me an aid so as not to have to disarm
10 years 10 months before #47018 by manual-mecanica
Manual-Mecanica Answer on the Perki
If you are talking about a marine engine, first check the salt water circuit, check the salt water pump, generally driven by pulleys or distribution.
These pumps, if girls, are with rubber rode and fail at the same time.
You can also have the water suction full of bugs in the keel.
Remember that marine engines do not have a radiator, but heat exchanger, so it may be that your engine does not manage to get heat from their refrigerant.
Check the status of sacrifice anodes and replace them if necessary, otherwise your engine is corrode
