Smoke by the Measure Oil Rod
10 years 10 months before #47039 by manual-mecanica
smoke by the measure of measuring oil published by manual-mecanica
Good, I have an Optra Motor Desing 2008, I bought it with the engine, ado and I made the machine, at 4 months I started throwing some smoke where the motor oil measure goes. And after about 9 months he started consuming oil, at 12 months he already bounced smoke for the exhaust, total that the machine did again, changed mechanics and rectification workshop. But it turns out that just a month ago and it is already throwing some smoke by which oil is measured again, and I do not know what it is finally, since the camera was rectified, valvul; new, new guides, new caps, the engine is directed and standar, new rings mahled brand. What is this time that it gives mineral oil since with the problems of Venezuela there is no semi -intentic. Please help me.
10 years 10 months before #47040 by manual-mecanica
Manual-Mecanica response on the smoke theme by the measure of measuring oil
Hi Siubher, I measure the compression to see, because I suppose that you know that all the engines "blow" something for the pumping of the pistons, but if it is too much it is possible to think that it has adjustment problems between piston and shirt and even if they tell you that it is directed and Standard is left, you cannot fully trust what they tell you and so assure yourself. Then this that the PCV valve is not blocked and does not let the oil vapors reabsorb to the admission. Greetings!
10 years 10 months before #47051 by manual-mecanica
Thanks Ismael, I will take it into account, the PCV changed it as soon as the problem starts in case.
10 years 10 months before #47056 by manual-mecanica
Well, you are not presisously repair of the engine or carry the rectified if something else Dieme the model of the diesel or gasoline engine to give you a more asserted diacnostic Chauu
