Smoke by the Measure Oil Rod
10 years 8 months before #47640 by manual-mecanica
Manual-Mecanica response on the smoke theme by the measure of measuring oil
The safest thing is that your PCV valve is glued or the obstructed line. You can hardly fail two adjustments in the same way, but it would be good for you to check the compression as recommended.
