fuses or something similar
14 years 5 months before #18394 by manual-mecanica
fuses or something similar published by manual-mecanica
Hello, I would like to know if someone can help me with my megane II that does not work for me or the lighter, the air conditioner, the mmotor of the run of water from the clean and I still do not know what more can fail. I have proven the fucible ones that are inside the habitaculus and all are correct and I would like to know if someone has come to happen to him and how he could solve it or will have to put a hand in the engine fuse box.
I look forward to answer thanks
14 years 5 months before #18445 by manual-mecanica
Manual-Mecanica response on the re: fuses or something similar
Hi Compi, you have to look at all the fuses and relays that are in the vain motor, because most cars the fuses and relays of the air, lighter, launched etc. They carry in the vain motor. A greeting.
14 years 5 months before #18449 by manual-mecanica
Friend the big problem that exists, when you get to that level it always has to do with corrective land points, desulfatellos at a general level and measuring some sudden continuity this party and no greetings are observed
14 years 5 months before #18470 by manual-mecanica
Sometimes the fuses look good, I stop the pins of these have rusty and do not make good contact. Sometimes just by getting one by one and putting them again, it is solved. I comment on your own experience.
