exesive consumption of fuel and faya when accelerating
14 years 3 months before #19784 by manual-mecanica
Hello, I have a problem with a 2004 Pointer which is giving me around 8kilometers per liter of gasoline which I don't know if that consumption is correct or is low in performance, I have noticed a fault when you want to pass or want to be suddenly shaken the car the car does not respond only slowly accelerating if you could help me I would appreciate it.
14 years 3 months before #19789 by manual-mecanica
Hello I have a 2000 Pointer and when this fault occurs it is for the ignition time since this model brings a distributor but if your pointer no longer has a distributor you have to check the potentiometer of the butterfly it is under the acceleration body wing the height of the butterfly and you must also check that all the marks in the tree pulley coincide.
greetings
