consultation
14 years 3 months before #19828 by manual-mecanica
Consultation published by Manual-Mecanica
Someone could upload the Distribution Seat Toledo 1.6 Gasoline 1999 and if it is advisable to change water pump thanks in advance
14 years 3 months before #19836 by manual-mecanica
Manual-Mecanica Response on the Re: Consultation
Hello partner, put the motor key (3lets that identify the engine) since there are versions 8 and 16 valves.
14 years 3 months before #19838 by manual-mecanica
Now I can't say the key but it's 8 valves thanks
14 years 3 months before #19844 by manual-mecanica
Better to give an infomming with motor key, the pump is convenient to change it, when placing the new strap and the tensioner the pump will work with a different voltage and that will surely produce that the pump throws you water soon, which causes you to reassemble the entire distribution.
14 years 3 months before #19879 by manual-mecanica
Thanks for the clarification a greeting
