Twingo
14 years 2 months before #20378 by manual-mecanica
Twingo published by Manual-Mecanica
Hello, I have a problem with my good twinging, the case is the second.
14 years 2 months before #20391 by manual-mecanica
Manual-Mecanica Answer on the Re: Twingo
Check the main fuses first, it is possible that the start has died.
Have luck and be little.
14 years 2 months before #20392 by manual-mecanica
Thanks for your help friend
14 years 2 months before #20431 by manual-mecanica
The most normal than the spoiled Ecu. A greeting
14 years 2 months before #20454 by manual-mecanica
Hello friend, as the partner says it is very likely that the ECU has burned and the alternator diodes should also have been spoiled, I hope it is mild the damage, tell us how you are doing, greetings.:(
