connection of an alternator .. ??
12 years 4 months before #40031 by manual-mecanica
connection of an alternator .. ?? Posted by manual-mecanica
Hello., I am new in the forum.
Could someone be broken how I can connect an alternator directly to a battery ??.
The alternator I have is a 120A Valeo.
It has a terminal with the letter B+
and a connection form with two connectors indicated inside with two numbers, (right 1) and (left 2).
ATTACHING ARCHIVE ALTERNATOR120A.JPG Not found
And add a photo, I don't know if it comes out.
all the best!
12 years 4 months before #40078 by manual-mecanica
Manual-Mecanica response on the topic connection of an alternator .. ??
The positive, what would be b+ to the positive of the battery, the negative ke is mass is the housing of the altermator. If keres that loads when you are walking that you have connected the cable of the regulator to the pilot lamp or easier but you have it to do vs is to make a bridge of B+ to the terminal of the regulator, it is to exempt it do not let it connected the bridge. greetings : Laugh:
12 years 4 months before #40079 by manual-mecanica
I understand that oh, to make a bridge interspersing a lamp between B+ and the regulator., the problem I have is that I don't know which the regulator's terminal has a brown plug and inside two contacts, but I don't know which one corresponding to the regulation ??? ..
8 years 2 months before #52125 by manual-mecanica
Hello, this can help you, while you have connected the B+ to battery
and the body to mass, verify which of the pins the witness lamp lights you.
Because a pin is the witness lamp and the other is positive on to excite the regulator, now if you give me the model, it can help you with the connection diagram
