Height Shirts in Peugeot 206, TU3JP engine
10 years 8 months before #47480 by manual-mecanica
Height Shirts in Peugeot 206, TU3JP engine posted by Manual-Mecanica
What is the tolerance, or maximum height of the shirts of a TU3JP engine of Peugeot 206 in relation to the cylinders block, because there was a need to fill with aluminum and brush the block because it was tarngled or with a twist
10 years 8 months before #47485 by manual-mecanica
Manual-Mecanica Answer on the topic Height Shirts in PEUGEOT 206, TU3JP Motor
For the Mot Tu3, the height between the upper part of the block and the support of the shirts is 90+-0.015 mm, the thickness of the Toric Board of the cylinder base is 1.15 to 1.35 mm, the survey of the shirts in the block is at 0.03 to 0.10 mm with a max difference. Between 0.05 mm neighboring shirts and measuring in different points of a single shirt between the block there should be no Max difference. 0.02 mm. (This is taken from a Peugeot workshop manual) I hope the data will serve you. Greetings!!
9 years 1 month before #50999 by manual-mecanica
Very good info ismael !!!, I was also looking for the same data for the Peugeot Tu3JP engine. I hope the tolerances are similar. Mario de Buenos Aires
9 years 1 month before #51000 by manual-mecanica
