Hello everyone, I have the next drama .... A Nissan D22 truck with the light of ABS lit, the Scaner throws me code 71 UNIT control in ABS module, I delete it and lights it on penalties circulates ... The sensors receive good signal and in tests emit the RPM of the wheels well. I do not have electrical diagrams to verify the signals in the module ....
what can I do ... I have no burned fuses or broken or cutting cables ...
Hello everyone, Code 71 .... Internal error of the ABS brakes controller ... I would check ground congnification and battery feed of the module, if this is ok ... you must test with another ABS unit, the masonal module is integrated into the ABS unit, it is changed as a whole. Good luck and greetings.
