Mercedes Vito 112 CDI
10 years 5 months before #48335 by manual-mecanica
Mercedes Vito 112 CDI published by Manual-Mecanica
Hello good afternoon I have a Mercedes Vito and I have been noticing that it has lost a lot of strength to what can be due can be the turbo
and what solution can have
10 years 5 months before #48337 by manual-mecanica
Manual-Mecanica Response on the Mercedes Vito 112 CDI
Check out if you have a pressure at the entrance of the Intercooler (re -approves the clamps for avoiding pressure losses), if you have no pressure or it is very low, it will be necessary to see if the turbo rotates freely, if so it will be necessary to think about the Turbo's electrovalve works electrically and check the emptiness tubes of this that do not have cracks (it is usually frequent this, the problem). Another point to check if the above is okay is the intercooler that does not have leaks both this and its tubes and clamps, try it with soap and water with the engine at 2000 rpm to see if you have leaks. Good luck and that the breakdown is little.
