Problem with the automatic transmission of an OPTRA
10 years 3 months before #48765 by manual-mecanica
Good morning I all have two problems with an OPTRA 2006
The first one is that I have not been able to open the Spanish manual of the automatic transmission that is available I do not know what program I will have already tried with all the programs of my computer
and I have an option that was made a general repair to the entire transmission,
seals seals are replaced
. If it was expected, half an hour, it walked but another one stays neutral
when the oil was removed dark and with a burning smell I have only disassembled the valve body and I found
a
lot Start when the engine started and by connecting the transmission in direct it took a bit to connect and then when it connected it with a symptoms the same with which I started before doing the general repair of the transmission in this way it followed the symptom until I present the problem that did not attract the speeds any or r or 123
thanks before hand to which I can help me
