Hi Escot02, (I don't know what are the "capuchones" ...) but for what you say: if only burns oil to a few revolutions; Possible wear in vessel or clearance in the guides of these, but if it is burning all the time, or you are broken some grease segment, or some scratch in a cylinder, or if they have mechanized the cylinders, they may not do it well and do not adjust the cylinder piston well. To disassemble the spark plugs to see how many are greased, if there is none, the thing can be in guides or seals of an escape valve. In any CCASA, lead him to look at him. Greetings!
