Good friends The problem of my car is that it places the hot ignition coils to the end that is damaged I have placed a 2.3 ohm resistor cable but then it fails, my coil is no longer heated is 2.6 ohm but searching in Google I got that the original boibna of electronic ignition with bosch 9220087005 ignition module that this uses coil with the previous ohmiaje said the other is that platinum coils serve in electronics on since those are usually 2.6 to 3 omh
PD. Buy a Bosch coil by Amazom of 3ohm but I think it won't serve me
