Salut J AI UNE MERCEDES 280SL 1985
9 years 7 months before #50339 by manual-mecanica
Salut J AI UNE MERCEDES 280SL of 1985 Published by Manual-Mecanica
ELLE DEMARRE ET S ARRETE?
9 years 7 months before #50340 By manual-workshop
Manual-workshop response on the subject SALUT J AI UNE MERCEDES 280SL of 1985
Hi, in this forum we normally speak in Spanish or English. I Hope that sumone can Help you with the problem.
I take this opportunity to translate what he says and that is that his Mercedes 280sl starts and then stops. If you want to answer you, you can do it in Spanish that the system will translate it automatically into Spanish.
9 years 7 months before #50360 by manual-mecanica
Manual-Mecanica Response on the SALUT J AI UNE MERCEDES 280SL 1985
Hello
I had a similar problem in a 300 recently took air and stopped after changing all the toric joints of the diesel filter clean and check tubes of the storage and hoses of the same
. Everything
I hope it helps you
