Hello to all the members of the forum.
I would like to make a consultation. I have a delicious mitsubishi year 98. 4m40 motor which is presenting the following failures.
It costs to leave in the morning, I have to help him with a clean contact, once he starts after a few minutes he stops in Readi. I have to return to him. That happens alone in the morning. Already when this is stabilized and I am walking and with a temperature of working as 2000 rpm passes the power and the check Engine is turned on. Decrease speed turns off the check Engine. I also listen to a small whistle in admission. I have not scanned it, I wanted to see if something can be done before spending money on scanning it. They tell me that it can be the turbo opening solenoid valve, air in the fuel system or it can be the injection pump.
Thank you in advance.
