Problems with XT 225. It has no spark
8 years 11 months before #51298 by manual-mecanica
Problems with XT 225. It has no spark published by Manual-Mecanica
Hello everyone ... I have an XT 225 year 2008. I present a first episode when I was normally walking at 70 km. per hour approx. Suddenly the engine stopped. I load her in the truck and take her home, regulate the valves, load the battery, and go until I start (after many attempts). Take it to a mechanic to check it, I notice it, without problems. He tried it for a whole week in the city to make sure that he was well, since he wanted to make a small 300 km travel. I do not present any fault, until I got on the route, I made 80 kms and suddenly turned off, as well as the previous time. The thrust, regulates valves, and has no spark. Check the entire electric part, even the stator (ignition) and all the values ​​give correctly according to the manual ... I have no way to test the CDI. The truth is that I am with the motorcycle at home a while ago and I don't know what it can be. I would thank you for any help, suggestion or if I spend something similar to tell me. Thank you
