Replace Lancer CB distributor 1992
8 years 10 months before #51333 by manual-mecanica
Replace LANCER CB Distributor 1992 published by Manual-Mecanica
Hello friends, first of all, I send them a cordial greeting from Venezuela:)
the theme in question is this: I have a Mitsubishi Lancer Glx year 1992 carburated, and the problem that I have been presenting and I have read in other forums is common, current failures by the coil; The detail is that the coil is inside the distributor and by the heat emitted by the engine over time, and begins to lose its efficiency to the point of not serving. I would like to know then if there is any proven way to change the distributor system to place an external coil and that other components would be replaced in the alleged case.
Thanks in advance for what they can contribute.
