Hello good ... that usually happens in a fuel feed system when the filters are partially clogged or covered. That produces that the pump consumes more common than desired ... It must do a lot of strength ... Do not cool correctly because of the sameness. If that should also notice what fails more when it has little fuel. A bomb should not consume more than 10 amps. I recommend checking filters and current consumed by the pump ... before replacing it.
