I would like to see if you can help me I have a Fraylander truck with an automatic box Allison and engine caterpillary my question is that I can check because at times it turns on the Range Inhibit light and the box stays in neutral ... what step I must follow and that checking to solve that problem ... Ya that the scanner does not give fault code ... from beforehand thank you
