Hello I need the Manual of a Ford Focus 2008
15 years 7 months before #10560 by manual-mecanica
Hi, I need the 2008 Ford Focus Manual Published by Manual-Mecanica
Hello, change the front rolls and turned on the Light of the ABS and the homocinetic joint is not dentated I do not know how to read that sensor
15 years 7 months before #10573 by manual-mecanica
Friend, the front bearing will be, the ABS sensors measure the bearings (rolineras).
The bearings in the rear should carry a magnetic band, if you are not original, those you have put, surely do not have it with which you will have to put them new again fixing that the magnetic band must Kedar towards the homocinetic, because the sensor enters through the hose to the ok bearing, I hope to have helped you.
all the best.
Everything you know about Ford I am your manual.
15 years 7 months before #10575 by manual-mecanica
Thank you very much right that was what I imagined but I didn't know
15 years 7 months before #10581 by manual-mecanica
You greet a greeting
8 years 3 months before #52059 by manual-mecanica
Manual-Mecanica Answer on the subject Hello I need the Manual of a Ford Focus 2008
It reads by means of a magnetic ring that is mounted on the dough beel
