Hello, friends of the forum, someone would have the kindness of facilitating the exploding of the Automatic W Polo 1.6.
I have a problem with the gear lever, the button that comes in it has been operated (pressed) and I will not give that any problem
the button is activated to change the march and when you put it in neutral it is blocked until you step on the brake so that it is unlocked.
Greetings
Jose David: Blush:
